MOMMURDA808
Its a 98 Auto kouki bone stock. Steering wheel vibrating at red-light, idle sits at 900 rpm. Motor mount is brand new. I checked alot of thing but still can't find out the problem. Please help! Thanks
bad driveshaft or driftshaft bushing
Hes got a new trans mount (nismo) along with the motor mounts
Tension rod or strut bushings shouldnt effect the car at a stop
true but this was also when i got new tires/wheels balanced + hub rings and new rotors and alignment so im also kind of bias at this point. he just needs to give everything a good pass over. if not maybe his steering column bolts are loose?
Usually the steering wheel vibration occurs when driving due to alignment/bent rim or warped rotors. Being at idle is a bit odd, Have you popped the hood when idling and examined the steering? You said you have a new motor mount, both are new right?Not just 1? If your at 900rpm idle, does it sound smooth or is it a bit rough? One of mine had this problem cause the idle was kinda high and was a bit rough, I adjusted it and it fixed it.
