booster seat
Well my sr is running insanely rich, no vacuum leaks, maf is good and clean, so i checked the tps and it is set. I looked at the fuel injector o rings and 3 out of 4 look to be in pretty bad shape, so im trying to figure out where i can get new o rings. Anyone have any? Also, have any suggestions as to what could be causing it to idle at 2200 and run suuper rich? The only thing i haven't checked is iacv.
These are the o-rings i found, they should work if no one else has any
http://www.frsport.com/OEM-Upper-and-Lower-Fuel-Injector--Side-feed--O-Ring-Gaskets_p_1325.html
