S13 With S14 Dizzy???
so i want to get rid of that middle wire on my distributor that goes to the ignition coil cuz im pretty satisfied with my wire tuck except for that. so can i put a s14 dizzy on there or am i gona need a s14 ecu and harnest?. thank you guys:D
I would assume you'd beable to use it just fine with harness and ecu. It's the same motor.
is it obdI or II? the s13 dizzy has the cps built in, the s14 has the cps on top of the transmission, as well as individual coil packs. if you want to eliminate the middle plug you need the s14 intake manifold, ecu, harness, i believe throttle plate, and transmission, so youll have the upgraded engine without the engine, doesnt make sense
A. what the fuck are you talking about. i got my motor from a s14 and its crank pistion sensor wasnt even on there and i drove the car before the motor was pulled. B. indivdual coil packs????? this isnt a sr its a ka which only has one coil. C. why would you need the intake....
just dont listen to this guy. and dont waste your time with this. there is a way to mod that s14 dizzy onto a s13 you just have to serch i belive nico there is a right up for it. imo its not worth the trouble.
yes!!! carlos beat me to that retarded reply!!!!
next time google noob-
http://www.ka-t.org/forums/viewtopic.php?p=339582&sid=5bc9b6f8d11c9d77d35b69dac6e8318c
