alright quick question i hear all this about rotary being unreliable and that they blow alot if i were to change my seals when i bought then engine would this be a solution how can i fix this issuE?
and after a while ?FlyinFINN said:You can get stock seals and be good for a while.
get rid of it for anther piston motor before it blows......alexanderig said:and after a while ?
nfs_emo_fag said:my first motor lasted 124k.
I bet that's longer than your 2j will last hahatrd88supra said:i thinks thats a world record
the way i drive id bet aginst myself toonfs_emo_fag said:I bet that's longer than your 2j will last haha
Junglist Muzik said:A rotary motor is like a women. You don't treat her right and she won't perform for you. As long as u keep track of fluids, coolant leaks, and good oiling, you should be fine. Don't just turn the boost up a little bit so u can win a race or the motor will blow. Treat it as any car should be treated and it'll be fine.
Devil Man said:what am i curiuos about is do these rx's have like a oil can that you fill up? like a motor cycle thats a basically how these things are they are dry sumped motors arent they?
