S seriouss14 Member Feb 11, 2010 #1 so does anyone here have a z32 maf installed on their S14 sr20det? how well does the car run and do u recommend it, or stay with stock sr20det maf? my maf is bad and my car wont start. will this help^? thanks
G gsracer BANNED Driver Feb 11, 2010 #2 this subject has been covered thousands of times.. You can not just wire up a z32 maf to a stock sr, you need to either retune the ecu, or install a safc and retune wtih that. Further more the only reason to change the maf is because you have maxxed out the mafs ability to measure air going into the motor. The z32 maf supports 550 hp, stock sr i believe around 280whp.
