Installing Door Panels
Status
Not open for further replies.
C Hernandez
I bought door panels and im not really sure how to go about installing them the correct way. Any Suggestions?
THANKS
True.. well as long as the tabs are on the door panels and the slots are still in the door, just put it up to the door like it would go and it should pop right in without much problems
Start by sliding the top of the panel down first - if everything lines up, it all pops in
You should be able to slide the top part of the door panel into the area/space between the window and door frame put that part first or else you won't get it right. Once its hanging then you align the clips into the holes and pretty much just bang em down with your hand should hear them go in. There are prob some screws at least one or two one on the panel and the other in the little hand hole space under the handle, depends on which car it is s13 or s14
thanks
INSTALLED! thanks for all the input
Status
