help with the stock ka
mca00176
im getting a stock ka24de i have a 20g turbo with piping already how much can i boost with a stock ka , with 72 lb inj and a fuel rail and a afc just an idea , thnx
talk to green machine
Dont get sr injectors. You sound like your looking to make alot of power. If thats the case sr injectors are not the way.
z32 maf + 555cc... which afc do you have? Well i dont remember correctly but i think the old afc can do +/- 50% or 30% correction, so i guess it doesnt matter because thats fine for this setup.
As far as boosting... i think you should go get the car tuned and go from there.
thts really crazzy on a stock , ka i really dought it with out braking nothing with a good tune im think about 15 pound tht would be alright i thnk
www.ka-t.org there's people running 15 psi stock internals, but you dont want to do that unless you run race gas or tune the ignition (because this is a NA ecu) along with the fuel maps. An safc wont let you do all that. So get your ecu chipped or get a stand alone or stop at 12 psi until you can afford it.
my pervious ka i ws booting 15 pounds i ws runing very very rich at the time i ran it for a year the only thing i had ws pistons and 550 inj i ran good but i messed arround with the fuel and the timing thts when i messed up the motor so on bone stock ka i can only boost 12
