Help: sr20 turbo lines..
AciDhAtch
can someone take a pic of there turbo setup(The lines from the turbo that go into the Block) so i can see how to run my lines. i got one in place but i keep fucking up on the other too trying to put the turbo back in.. Thanks
the line in the top of the turbo goes to the bottom hole on the block. the hole on the turbo facing you(if you are standing on the driver side) goes to the higher hole on the block. the bottom hole on the turbo is the oil return and goes to the oil pan, and the closest hole to the block in the turbo is coolant feed and goes to the coolant line on the back of the head.
i hope this makes sense
+1
THAT^
thats the one that i was saying is closest to you when standing on the drivers side of the engine bay.
