Having Problems With The Driverside Door. When I Close It, It Doesnt Lock, Like If Its Not Alligned Right. Also I Put A New Hood And The Front Doesnt Seem To Align Right Can Someone Pleasse Help Me.
ok, the hood ther are these little rubber grommets on the radiator support brackets that hold the horn, newaiz, u want to adjust those, i htink they can screw up or down, same thing with the hatch
....yup, i was going o say the same thing....the front rubber studs can be an issue...if its not there...if you look at the latch for the hood locking mechanism located on the radiator mount... i believe you can adjust it up or down. ....i learned a lot building my 240! ...you never truely understand untill you do it yourself!
