fuses getting hot
alibaba
Ali Nassar
what does that mean?
the fuses for my blower motor blew today, and when i went to check the fuse it was pretty hot and it started to melt the fuse.
could it mean a short??
if it was a short wouldn't it just blow the fuse?
had the same problem with 86 i had split under my fuse box that was grounding out when i turned and killing my fuel pump. id def look for a split wire on your blower motor and under the fuse block
Resistance would not cause anything to melt. It's a short. Might be the blower motor itself. Has your blower motor been working fine lately?
