Energy Suspension Bushing Install Guide!
Kenrik
Post in Progress.. check back later for more!
Sway Bar End Link
Purpose: Sway bar endlinks connect the ends of the sway bars to the struts.
Tools: 14mm Socket
Parts
Assembled
Install
Now do the other side!
Finished!
_____________________________________
Tension Rod
Purpose:
Tools: 17mm Socket/Extension, Blow torch, Sawzaw, Hammer, Flathead Scredriver, File, and depending on the kit a press*
*press not required for the "new" 3pcs kit.
Parts
Bushing Removal:
Step one: Set the ***** on Fire!
Step Two: Cut the inner metal ring (do not cut the outer metal) with a Sawzaw in about four places
Step Three: Pound the inner ring out with a hammer and flathead
Step Four: Smooth the inside with a file and install grease
Step Five: Install bushings and center copper piece
Hmm... Burning rubber! Smells like a drift event! :naughty
Assembled
Install:
Reverse of removal
Now do the other side! :cry:
Finished!
Oh sh!t good job, I see your doing the same thing im doing. Installing everything you have now that the car isn't running yet ;). Keep up the great work :D
What about the Sway Bar Bushings, Control Arm Bushings and the rest of the Master Kit
