ATTENTION:
ALL DRIVERS MUST WEAR PANTS AND CLOSED SHOES!!!
ANY DRIVERS WITH SHORTS AND SANDALS WILL NOT BE ALLOWED TO DRIVE!!
Gates open: 6PMALL DRIVERS MUST WEAR PANTS AND CLOSED SHOES!!!
Drifting starts: 7PM
Event ends: 11:30PM
Cost: $25 to Drift, $10 to Spectate, $5 to Ridealong
Tech requirements:
13. PANTS AND CLOSED SHOES ARE REQUIRED FOR DRIVERS AND RIDE ALONGS
Guidelines:
1. DO AS I SAY!!
Questions/comments/concerns, post it here.
FAQ:
Yespay at the gate?
tandem requires cage?
No. We recommend it but it's not required.
where's this event at guys? i want to go..
http://maps.google.com/maps/ms?msa=0&msid=110934348244118805165.0004360875412c4c2f91a&ie=UTF8&z=19
