hachi
ATTENTION:
ALL DRIVERS AND RIDE ALONGS MUST WEAR PANTS AND CLOSED SHOES!!!
ANY DRIVERS WITH SHORTS AND SANDALS WILL NOT BE ALLOWED TO DRIVE!!
Gates open: 11:00AM
Drifting starts: 12:00PM
Event ends: 5:00PM
Cost: $25 to Drift, $10 to Spectate, $5 to Ridealong Ladies ride free!
Tech requirements:
13. PANTS AND CLOSED SHOES ARE REQUIRED FOR DRIVERS AND RIDE ALONGS
Guidelines:
1. DO AS I SAY!!
Questions/comments/concerns, post it here.
Gates open: 11:00AM
Event ends: 5:00PM
Tech requirements:
Guidelines:
1. DO AS I SAY!!
