D Duck Spectator Nov 21, 2006 #1 ok i have an s13 my divers side door used to open just fine then one day it started poping and now i try to get out of my car and the door catches the quarter panel. (left a big dent -_-') anyone know how to fix this??
PlatanoDrifter Authorized Drifter Driver Nov 22, 2006 #2 show pics of how it sits and were the door bolts up so we have a better idea of wht u mean
I illsuspect Member Nov 22, 2006 #4 either you hit something or somebody hit you but something caused the quater panel to shift back towards the door
240SicknessX forgot how to drive Driver Nov 22, 2006 #5 the quarter panel in in the rear, fender is in the front. Which peice is hitting what? Are your hinges loose or something? Off the sliding track?
HellaSFLDan Driver Nov 22, 2006 #7 its called frame damage...warped frame...240sx...idk there are probably some other names for it too
K Ka24coupe Member Nov 23, 2006 #8 Lossen The Fender Bolts And Adjust The Fender, Loosen The Doo Hinges And Move The Door Onces Everthing Has The Coect Spot Tighten It All Down
