Nismo240sx
my oil pan is dented. and i wanted to know if i need to replace it.
you got lucky when I hit mine it covered the oil pick up and I blew the motor like a dumbass
i got a 2nd ka . imma just use that that oil pan out. yal kno how to remove it the best way. i only kno by remove the sway bar n jacking up the motor from the bell houseing
Pull it out, and hammer out the dents. If you do a good job you should be fine. If it still looks like shit just replace it. And since you're dropping the pan, replace the gasket while you're at it. GL
Hammer it out or replace it you got lucky when I hit mine it covered the oil pick up and I blew the motor like a dumbass
Il change it for $150
Best post......
now y would i do that...if u can help me then do so..if not dont post dumb shit
