i got a set of their inner/outer tie-rod combo that has the spacers for the bump-steer adjustment settings. Had it for about 2 months or so and i hit a pot-hole while making a turn and my steering goes loose/off-center. Turns out the inner tie-rod where it connects to the outer tie-rod stripped/ripped out. Luckily i was a few blocks away from home and able to limp it home, and didn't happen the night before when i was doing 120+mph....When i took them off to replace with the TEIN combo, the spherical bearings were also pretty beat up and were kind of chewed/dented. The lower-brand companies use crappy spherical bearings/joints. I just purchased a set of Peak Performance Tension rods and they use the "AURORA Rod-end bearings" which are the shit. much better quality than what you will find on the megan/Circuit Sports etc. parts. You get what you pay for. Have no doubt about that. :bigthumbu
