coolant leak
6thSphere
i see a elbow, leaking coolant. It's located on the intake manifold. Directly behind the ps pump. do i have to change the whole intake manifold or is that a fitting i can buy?
picture would help, im guessing sohc if so thers several coolant "elbows" anf if it's leaking from the metal fitting u can try to jb weld it or u might need to replace the manifold at which time u can delete the emmisions and bypass the coolant line that goes thru the throttle body if u already havent
yeah its a sohc. it is leaking from the metal fitting. it is the fitting on the manifold, and its closest to the ps pump. If i block off that fitting and block the incoming coolant off, will it damage anything? i don't see the purpose for the coolant to go to the intake manifold.
if any one has an intake manifold for an sohc lmk.
thanks
