JTNismo said:I just posted on an overheating issue last week and got a lot of feedback.............maybe you already saw it but if not here it is. It might help:
http://www.sfldrifters.com/forums/showthread.php?t=17687
I also posted on how-to for a radiator water system flush just in case u need one too all these good people really helped out and my car is back to normal...........
http://www.sfldrifters.com/forums/showthread.php?t=17735
md2020 said:My engine overheated due to the radiator being clogged.
I'd say to check if it's clogged drain out the radiator fluid and look straight into it. If it's clogged you'll need a new one. When you put a new one in make sure to bleed it.
z4k said:
Thanks for posting those LINKS JT. Way to help out! Keep it up.
As far as checking your radiator the ways mentionsed above give a bit of insight. If you have the radiator out of the car run water through it and see if it comes through rusty or clear and if it flows well.
