Advice please , need help
ROIDMONKEY
ok i dont want to get annoying with this again but id like to know everything i need so my engine swap goes pretty smooth and quick ,
so far what i have is
power fc (SR2015)for a 94-96 SR
HDI boost controler
SR20DET 94-96 (in 2 weeks)
BOV
front mount intercooler( need piping) anyone have experience with the ebay ones? those are heap and looks ok
Im getting eaither 550cc o higher cc's injectors
HKS ( i think) exhaust system (or you guys have a better suggestion) the deeper the sound the best
Do i need down pipe?
Do i need motor mount? or the KA fits?
Do i need a better radiator? with fans? Im looking for 300 at the wheels at least
I assume that i need boost ,(and what else)gauge's right , wich one u guys suggest
the car have TEIN HE allready and LSD
thanks guys ,i appreciate your help
HDI boost controler
BOV
u need a downpipe
walbro 255 fuel pump
new motomounts nismo ftw
ebay piping almost always has to be modified i recomend greddy mspec for $400 fits perfect
stock rad is a lil iffy u def need fans but u should just buy a mushimoto or koyo alluminum rad and a fan from advance will do fine
u dont need guages but i recomend boost and oil pressure
if u aint movin the battery to the back u need a lil odyssey battery
buy allllll your fluids gear oil,motor oil, etc
idk if i missed anythin but that should be fine
koyo ftw. i blew up my stocker on the highway...
ebay front mounts are ftw. i know like 12 billion ppl using them.
is it s13 sr20? i wouldnt be messing with that VTC garbage if i were you...
thanks JDM and choku
im geting a 94-96 SR cause bough the power fc first .the guy had it running on a 96 SR if not i would go for a redtop guys
sorry for my ignorance but whats FTW :)
you blew up ur radiator??? is ur headgasket fucked?
oh srry for thread jacking. anyways if u want a smooth install, get the engine, harness, stock ecu, new motor mounts and a downpipe. and put it in with everything stock and drive. :)
its a downpipe
300 hhp huh....lol....gt2871r right there
or a gt25 would be nice
"TURBONETICS T3/T4 TURBO" doesn't really tell u that much. what trim, what a/r, what stage wheel...
your best bet before getting into the swap and throwing down all this money is to do a lot more research and reading. The s-chassis and Sr20 has been around soo long most things have been done before and there are many recipe's for so-and-so wheel horsepower. it's always good to be fully informed and aware when getting into expensive projects like cars. Good luck, and she should be a blast to drive once u have her assembled.
My tip for dropping the Sr20 in is to have the motor mounts attached to the Motor, and not the sub-frame. First time i bolted the mounts to the sub-frame it took me 2-1/2hrs to get the first mount positioned and never got the 2nd till i remembered reading that it's easier to put the mount on the motor and line the mounts/motor up with the sub-frame. Afer i remembered that i bolted the mounts to the motor, and 15 minutes later the motor was in and bolted up. :slap: .
thanks for that advice bro , yes im reading and getting myself informed , believe me i spent more than 4hours last night reading and searching , Im not going o do the swap unfurtanely i dont live on a house , so cant do shit here at condom
for VR6 48 trim, .63 a/r
m4nfred said:
its a downpipe
ok i just got a GT25 ,60 trim 60 mm compressor, (.60 A/R hsg), w/ 60 trim 53mm GT25 turbine wheel in .60 A/R based
paid 278 including shipping
EBAY
lets prade is in good working conditions :) , guy said it is and no need to rebuild
