[size=+2]Gates open: 6PM
Drifting starts: 7PM
Event ends: 11:30PM
Cost: $25 to Drift, $10 to Spectate, $5 to Ridealong[/size]
[size=+1]Tech requirements:[/size]
[size=+1]Guidelines:[/size]
1. DO AS I SAY!!
Questions/comments/concerns, post it here.
[size=+1]FAQ:[/size]
Yes.
Event ends: 11:30PM
1. DO AS I SAY!!
pay at the gate?
Yes.
No. We recommend it but it's not required.tandem requires cage?
http://maps.google.com/maps/ms?msa=0&msid=110934348244118805165.0004360875412c4c2f91a&ie=UTF8&z=19where's this event at guys? i want to go..
